Has anybody gotten an alignment and compared it to a measurement at home? I'm pretty decent at math, and just can't make any sense of things. I measured the difference in back to front at two difference places very carefully, getting back measurement of 65 7/16" and front measurement of 65 10/16", for a difference of 3/16" toe-out (yes, odd to have have toe-out, fixing that but wanted to get a baseline first)
The alignment sheet from a recent check shows total toe of -0.07 degrees and the first way I calculated degrees used my actual tire diameter (Krawlers are 34.5"):
arcsin (3/16 / 34.5") = 0.31 degree toe out
I'll bet their Hunter system doesn't account for after-market tire size and uses what is probably in their system for a 1972 Bronco for default tire diameter. That actually makes it worse since the factory tire diameter is smaller:
arcsin (3/16 / 29") = 0.37 degrees toe out
This website looks like they do the math the same as me: link
I know I'm overthinking it, mainly interested if somebody has gotten an alignment and also has an at-home measurement. If you have, can you post up the details please?
Is it possible that bigger tires and wider tires are totally throwing off their system. Seems like toe should be an easy thing to measure on alignment machine that wouldn't be affected by tire size.
P.S. I've checked for slop in front end that could be contributing to weird measurements and all seems tight.
