- Apr 21, 2004
- 618
Guys, I'm getting ready to tie my cage to the frame using the Complete Off Road Kit's. At the front tie-in's there is a gusset on the underside that is in the way which has to be highly modified or eliminated all together. On their website it looks like it was completely cut out. Before I start cutting I was hoping for some incite on what others have done. Also, is there any problem with stability in that section or is it made up by the tie-in kit. If not what have you done to fix that problem. As a side note, I am adding bushings to the kit. I posted the link so you can see their install photo at the bottom of the page.
As always thanks in advance for your expert advise, Ed
http://completeoffroad.com/i-123519-tie-into-frame-kit-front-hoop-66-77-bronco.html
