Completely stock 1967 Bronco
D.R.Y.
The Netherlands
I know this question has been ask a hundred times. But I have not seen a definate answe. I have to special order the tires over here and they do not take them back. So I am doing a frame off restoration on my 1967 Bronco wagon. I will be keeping everything stock. So my question is what is the biggest tire I can put on stock 15" steel rims?? I plan on buying BFG A/T
Stock tire would equal 205/75R 15 and other threads have said 235/75R 15 will fit with no rubbing.
Thanks in advance .
Beer and Fish
If it's completely stock why are you asking for the biggest tire that will fit? Completely stock is 7.00x15.
D
D.R.Y.
The Netherlands
Bedankt Elan. i will get the 235's. Reason for the biggest tire is for the fuller look instead of skinny looking tires.
Thanks for the fast answers
jckkys
To answer your question, you have to define what you mean by stock. In 1967 the stock tires would be 7.35x15 with optional 6.50x16s. By 1973 L78x15s were optional these are equivalent to 235/R75 15s and do look good on any early Bronco.
jckkys
The point of my question is, stock for some early Broncos isn't stock for '67s. People concerned with doing a correct '67 restoration won't use tires correct for '73-'77 Broncos.
House
Minutia Militia
One more vote for 235/75-15
patterdale
This is what we have on Elmer. No rear rub but hit radius arms in tight turns.
Rustytruck
My 1974 Ford Bronco came from the factory with H-78 X 15" tires they are 28.3" tall. metric 225-75R 15 which are 28" tall
okie4570
NW OK
Powerkings come in 7.5x 15" and 16"........will run you between $90-$125 depending on where you buy plus shipping.
Whoaa
I have a few Bronco's, some modified and some stock. On my all original 73' model I'm running 235/75/15
