Bilgamesh
I have a '74 Bronco with a stock 302. It has 135K mi. on it and idles roungh. I bought the compression tool and found I have the following compression in sequence from cylinder 1-8: 90, 30, 115, 160, 10, 130, 160, 130.
My stepdad the shadetree mechanic said it could be blown head gaskets, valves or rings. My question is how would one know if a gasket, valve job or rings would do the trick, or a complete rebuild would be required? The engine does not smoke, and all plugs burn clean.
