trailpsycho
- Dec 11, 2003
- 4,856
Everyone is probably familiar with the PowerTank and Ultimate Air set-ups. Everyone also realizes that space is at a premium. Powertank offers a mini-system for just ARBs ... http://www.powertank.com/products/productID/141 , but at close to $300 I decided to look around. I visited a paintball shop and talked to the guys there and came up with about a $125+ solution to dropping the paintball tanks to the 85-100 PSI needed for the ARB, problem was there was three or four different fittings and the end of the bottle looked like an erector set. I remarked to the guy that it would be real cool if someone made an all in one solution. He suddenly had an epiphany and recalled a brand-new product he had just heard about made by Kobalt and sold through Lowes. SO, I went and checked it out.
Its called the Portable Compressed CO2 Regulator. Its a kit that comes in a hard plastic carrying case; complete with quick connects installed on the regulator and hose, extra QCs, an air chuck, a pressure guage, an air gun, and--too good to be true--safety goggles. The regulator is fully adjustable to from 0 to 120 PSI; its meant for construction work--nail guns, etc...which is pretty darn close to how the ARB will function. Built in on the regulator is a belt attachment-sort of viewable in my hadn in the pic-it pivots to keep the tank upright...which could even be funcitonal for wheeling I suppose. Its pretty compact ~14" tall for the whole assembly of the regulator ( on top of both the 9 and 20 oz bottles). The best part is that its fully portable--with the case or without....hard-line your ARB plumbing and install an extra check-valve or an additional air toggle to terminate the system; then when your ready to rumble, quick connect in the CO2 tank, open your valves and operate your solenoids or air toggles. When your done, wheeling, close the safety valve on your air system, quick disconnect the tank and stow it while your in town. The 9, 12 or 20 oz cylinders are smaller so you can carry one or two extras at any time. Lowes now carries the 9 and 20 oz CO2 tanks as well...in the Blue Rhino line, so just like propane, you just bring in the empty and for $8 you get another 9 or 20 oz. not the cheapest way to go, BUT you can --or soon will be able to-- get them almost "anywhere". It is cheaper to buy your own tank(s) from a painball supply ($~15-20 + $4 to fill), but --for now-- when you buy the Kobalt set-up they throw in a free 9 oz filled cylinder ($24 value). So for right at $100, I can operate my ARBs once I plumb the system.
You still need a pressure relief valve (back-up; for the safety of your system), the air-toggle switches and plumbing materials...any way you slice it, its a much better deal than the comparable Powertank application...even after I buy another cylinder or 2 or 3, protective booties for the spares, fab a mount, etc. If plumbed right, anything worthy of 'attention' will be totally portable (by you), so you can lock it up, take it on road trips with the family, run air tools at home or on the trail--temporarily, or in a pinch--which may burn a significant portion of one of the smaller sizes--to seat a bead, which should be possible at 120+ PSI, general air up, etc.
I know its more economical to run a 10 or 20 lb tank, but if I can fill up four 20 oz (5 lbs of CO2) for the same price as a 10 lb tank...then the trade-off for the space savings and security--of my OBA system and that of my passengers--is worth it to me.
Just throwing it out there as a new take on an old idea. I think it will be cool for keeping the interior 'boring' to passers-by-with a wondering eye, transportability (my own) and easy lockable storage. I will post up some pics when all this is installed and operational over the next month or two. Best.
John
John
