Ok guys, I put a new intake on my 302 and replaced all the hoses had to move the temp sensor into the intake housing for the upper radiator hose, I started it up today only could put about 2 gals of fluid in it and all it does is pressure up and the temp just keeps going up. It calls for 4 gals I think. I cant get enough fluid in the radiator to keep it cool. But im wondering if I have a thermastat problem, maybe some air in the system. All of the hoses including the heater hoses are hot. Im not sure how to get the air out of the system if it is.
Last now that the temp got sorta hot 220 maybe, after I shut it off and turned the key back on the gauge pegs and stays there. Is this a normal thing for broncos or do you think its in the gauge.
Brandon
Brandon
