Cooling System Overhaul
coachbarnes
Franktown/Breck, CO
I'm preparing to take my Bronco on an adventure down the Baja Peninsula, so I'm doing an overhaul of my cooling system. 302 roller block, EFI. Pretty darn stock. I've not had any previous overheating issues, this is more preventative stuff. Having the stock radiator vatted and pressure tested, replacing thermostat w/a Robert Shaw, etc. A couple of quick questions;
1. I've got a flex fan on there now, but have a steel fixed fan. Which is better for cooling at low speeds and why?
2. It currently has a water outlet with a 90 degree angle, but I have one with the stock 45 angle. I can't use stock hoses with the 90, so any reason to NOT go back with a stock 45 angle?
3. I happen to have an aluminum pulley laying around. Any reason to NOT use it? Other than bling, any advantage? Seems like I've heard the aluminums will give you some belt squeal with a high amp alternator (which I have).
4. I'm replacing the water pump with a FloKooler. Should I use anti-seize on the water pump bolts?
SteveL
Huge chevy guy
Hawthorne ca
If you don't have a problem now I would go with a decent stock pump from napa. I put a flowkooler on one of my rigs and it caused nothing but problems. Don't know if water moving thru too fast or what. Went back to stock and it was fine. I fixed fan will move more air. If you're going to a stock tstat housing get a stock cast one. Most of the fancy chrome ones I've run across leak. Most not flat on the bottom.
jw0747
San Antonio, TX
Solid blade fan is my choice. Have one on mine and never an issue. Install a new thermostat if you change housings.
jckkys
The OE 7 blade flex fan is the best period. Fixed blade fans are just a lot noisier. The stock type 45 degree thermostat housing made of cast iron is the most trouble free. The long stretches between towns etc. on Baja make reliability a major concern. No AAA down there. The OE steel pulleys are the most reliable. I run a 2 groove pulley on the crank, water pump, and alternator. The power steering belt also goes to the other 3. The loss of either belt will not leave me dead in the water. Spares are a good idea too. The 2 belts eliminate high amp squeal at the alternator. Be sure you check tires, belts, battery and hoses.
sykanr0ng
The 90 degree housings came about to get the hose to clear the serpentine belt systems, so no serpentine = no need for a 90 degree.
coachbarnes
coachbarnes
Franktown/Breck, CO
That’s odd, Steve. I’ve run alum FloKooler pumps on all mine, including my desert racers. I even run one on a little U13 with a 170. Never a problem. What sort of problems did you have?
Sent from my iPad using Tapatalk
englewoodcowboy
Lick Creek Restorations
My personal opinion is to go with a new core on the radiator. I actually buy the new 4 core dense pack copper/brass radiators from Wild Horses.We install AC in most of our builds so cooling always becomes an issue and with that setup it is not. If you are running the traditional pulley system, I also upgrade the fan to. A clutch type fan. It moves a lot more air and you gain a quieter system as the fan engages as it is needed so it also frees up a few ponies. I would def flush the block to remove any scale or mineral deposits as well as others have suggested, new pump, thermostat etc. You can also run a bottle of the water wetter type additive to your system when you refill it to make it as efficient as possible. The new fan clutch and fan can be bought through summit, Hayden brand and if you are interested I can get you the part numbers.
coachbarnes
coachbarnes
Franktown/Breck, CO
Thanks -- I've run the BC triple pass on my Baja racers w/351's and never had a cooling issue. Also had big external transmission coolers w/electric fans on those. But I want to retain the radiator cooling for my C4 on this one (with a small stacked plate trans cooler), so the Triple Pass wasn't an option. I didn't realize WH had a 4 core copper. I'll definitely give that a hard look.
I guess I don't understand how the fan clutch works, and what advantage it gives you? Why would it move more air than a fixed blade that is always spinning fan?
SteveL
Huge chevy guy
Hawthorne ca
It was on a stock 350. It ran good with no cooling issues.. the water pump was going so I figured I'd upgrade to the flowkooler. Didn't change anything else. I forget if it was just on the highway or all the time but it was constantly heating up to bad levels. I put a stock pump back on and it was fine after that.
englewoodcowboy
Yes, they make the same 4 core but not in triple pass so it has the trans cooler built in. They work great. As for the clutched fan, the fixed blade moves more air by design, the clutch can slip or go full lock depending on needed cooling. When it is locked up it moves a massive amount of air compared to the factory flex. The major added benefit is in noise reduction. It's somethgin the factory migrated to later for better efficiency all around. If flex fans were better we would still see them today and they are a thing of the past. The electric setups could be argued to be a step better yet but they are used because they no longer require exact line up of motor to radiator for fan placement as well as they can be configured as a pusher or puller, again freeing up space for the complex systems today. A clutch fan is the next best thing and does not depend on another system to function in my opinion.
coachbarnes
coachbarnes
Franktown/Breck, CO
Got it! I just got on the WH site and I'm going to pull the trigger on one of their 4 Core radiators, since everything else is going back new anyway.
So I guess the clutch simply engages/disengages via RPM's? Honestly, In Baja I'm into simple so if a decrease in noise is the big advantage, I'll probably just stick with the rigid blade, always spinning. One less part to mess with.
Thanks for the help - always appreciate everyone's comments, opinions and feedback on this site!
englewoodcowboy
The clutch fan always spins, it is temp controlled meaning it is allowed to slip so it is not turning the same rpms as the motor, this. What reduces noise and releases power to the motor, as it gets hotter, the slip is reduced until it locks up 1:1 and at this point is moving close to double the air that the stock flex blade can. It is a very simple system and bolts right on. We are installing one right now for a customer, it won't be finished till later next week as we are doing a bunch of other work on it.
SteveL
Huge chevy guy
Hawthorne ca
I don't know a bout the wh 4-core but do a little research. I had one of the 4-core conversions on the 66 and it kept springing leaks. The local radiator shop said it's common with they put the 3-core ends on the 4-core radiators or whatever they do to build em. I swapped to the standard bc 3-core and it runs cooler with no leak issues..
Seventee
In the sticks of MT
I also run a fixed fan, in fact I think it is the same one you have pictured if that's a Derale.
It is a noisy sucker though! Not sure if it's because of that particular fan design or what. But I am seriously considering putting the effort into changing to a clutch fan, which has been the best setup on my '79s. I've never had much luck with aftermarket flex fans.
knack
Are you running an automatic? Are you towing anything?
I haven't had any cooling problems with my stock 302, flow cooler pump, 4 core radiator, stock fan - until I was in the Moab area last spring. Still no engine overheating, but pulling a thousand pound trailer up long hills I had to stop often to let the transmission cool off. I've got a transmission cooler mounted in front of the radiator, and use the trans cooler in the radiator.
Next time I'll have more cooling. Maybe a trans cooler with fan?
coachbarnes
coachbarnes
Franktown/Breck, CO
I originally planned a trans cooler with a fan, but didn't want to sacrifice the space and also didn't want to add a fan, which is a point of failure. (Baja dust eats electric fans for breakfast). I opted to use one of these, along with the radiator cooler. I think it will give me plenty of cooling for my transmission. I'm not hauling anything other than my big ass! lol Derale Trans Cooler
coachbarnes
coachbarnes
Franktown/Breck, CO
It's a Derale. I'm not sure how you guys know the fan is noisy on these EB's.. I can't hear anything when I'm driving it as it is... ;D;D
