copper header gaskets
Mark
Bronco Klutz
NW Indiana
I ordered (finally) the Hedman Headers from Jet Hot today.
LSUPete really raves about these things.
2 week lead time (it will probably be another month before I finally install them %) ) anyhoot,
I don't trust the paper gasket it's coming with, where o' where can I pick up a good copper gasket and locking bolts for these?
73stallion
Eugene, OR
i suggest you look at the new ones that chuck sells. i think he gets them from earl's (they look like them). i have earl's on mine and they seal great. multi layer aluminum.
SteveL
Huge chevy guy
Hawthorne ca
I'm running the copper gaskets on my 72 and they work great. I've been running the aluminums in the past and decided to try these. I like em better. Put a bead of permatex high heat black on em and they should be fine. I've never had to re-tork mine with the copper. you can get em from summit.
wildbill
Old Bronco Guy
;D ;D ;D Talk easy I have the paper ones and if done right they will last a long time. I put them on in 86 when I changed headers. I have not had any leaks or problems with them. When you use them torque run hot torque let cool retorque and then just go play good luck. ;D ;D ;D Bill :cool: %) :p
