Core Support Differences
ngsd
Just replacing the core support on my 66 and ordered one 66-76 from WH. Seems quite a bit different and just trying to see if this is the right one or is there a different one I should order.
What are the differences and does anyone have pictures of them year to year and 6 or 8 cyl?
Do you have a pic of your original? And did you receive your new one already that you could photograph side by side?
The radiator openings for the early ones were smaller, even if they came with the V8 apparently. I used to think the small opening was just for the six-cylinder engines, but my '68 has the small opening and it had a 289 in it originally.
I believe that there were some small differences in the oval vent holes near the battery. The battery brace bracket, and hood strut brackets were slightly different, but only just.
The big changes came in very late '72 when the big opening by the battery for the cold-air intake, and the bumpout for the power steering box were added.
I'm pretty sure that all the bolt holes are the same, including those hidden ones up under the fenders. The hood latches were pretty much the same all years too I think.
The upper corners where the triangle braces are (supports between the inner fender aprons/skirts and the core support) might be different, but I've seen differences just from the Chinese factories making the parts too! So that's hard to quantify.
Let's check out some pics if you don't mind. It's not uncommon for anything from '66 to have some oddities that are not accounted for in '67 and later models.
ngsd
ngsd
I knew Paul would answer this!
Yes I should have posted those before.
The hood latch area looks very different but have not tried anything yet
Must be some kind of mounting differences then, because even your early one got the large opening, the power steering bumpout and the cold-air intake hole.
And now that I look at it, I see we only sell the one part that covers all years and is based on the later '73 to '77 model. Just like it looks yours is.
I thought at one point we had both styles, but it probably wasn't worth it to make new ones for two different styles except for those that are doing restorations. Where this would not fly.
I was afraid you were going to comment on the latch area. I'm not familiar with any differences on a '66 vs the later ones. Hmm, now you've got me wanting to check my '68 out just to see if it's more similar to one or the other.
I bet the '66 is a unique one. Looks like the holes are spaced the same, but the safety catch is different. Or non-existent on the early one? Does your hood have the dual-stage latch like other Broncos?
Just out of curiosity, what month was your Bronco built in?
ngsd
ngsd
I don't know when it was built. The Vin is 834030 but not sure what that tells me. The hood was already gone on this.
okie4570
NW OK
March 66 build, did it come with a 6cyl or 8cyl? F or N in the vin?
ngsd
ngsd
Now I am curious as to what VIN the first V8 was! Not that it matters as this is far from restored but that is still interesting. I decided to use the later model core support as the original is just too beat up. Seems to fit OK and measures out pretty close to my other 66.
okie4570
NW OK
Not sure on the earliest v8 vin number on way to know for sure. Just have to start compiling a list of N vins and then it's just a guess at best.
72_EB
66to77
Your original core support you have there was unique to the '66 and early '67s 289s only. They are quickly identified by the full length radiator mounts. The 170 and later V8 cores were different.
ngsd
ngsd
Thanks, my other 66 has the same so I was wondering about that.
Well lovely. So what becomes the best way to proceed?
Making the new one work? Finding a good used '66? Bit of both?
ngsd
ngsd
Well as I mentioned above, since it is not a correct restoration I used the one I got from you. My bigger concern was how everything fits. As long as the hood latch works I should be OK. The picture above is the new one I that I already put in. The fenders seemed to align well and the measurements from cowl to nose are equal to the other 66 I have so crossing my fingers. I have it all put in with sheet metal screws so far and test fitting until I weld. If I were restoring this to original I would search for the correct piece or repair the one I have.
