Cost effective trailer?
tommyg
Guys, any recommendations for a trailer to tow the Bronco that won't break the bank? Appreciate any thoughts.
Bukin 67
Bronco Abuser
Mine's a 16' Carson with a wood deck built here in So CA. I fount it on Craigslist for $1599 new 3 years ago. It's been all over including to the tip of Baja and back twice without fail. Check Craigslist in your area.
I had to weld D rings on the sides to tie down instead of the boxed ones that came on it. Also added an open storage box on the front and mounts for 3 spares.
Pics:
sprdv1
REBEL
do your research local, etc.. I found a guy here, 18' flatbed, for just under $2k at the time..
Sometimes can find em on here or on craigslist...
bearskinner
N.Idaho, AK, SoCal
Sometimes your better off purchasing a nice new trailer. I've seen some hard used trailers, that need tires, maybe bearings, the wood deck is shot, and they are all scratched up, ready for a repaint. Check it out good. There's a lot of junk out there.
tommyg
tommyg
I'm guessing that a 14' would be the minimum size that would make sense.
56f100bbw
Tucson / lakeside AZ
I am with bearskinner buy new you won't know if it's been overloaded or abused and I have seen it and a min 16 ft long my aluminum trailer is 20 ft
hyghlndr
Hockessin, Delaware
U-Haul rental if you only use it a couple of days a year is probably your best bet. Other than that I wouldn't go any shorter than 16 ft.
ared77
Agree, 14' you will be wishing for a longer trailer.
Nothing Special
You asked about a trailer, but two other options (if you haven't already considered them and thrown them out) are flat towing or a tow dolly.
A tow bar is pretty cheap. I built mine for probably around $50, I'd guess a few hundred to buy one. You really should add "toad brakes" which isn't cheap, maybe another $1000 - $1500. And according to the manual you need to drop the driveshaft every time you tow it. So it's got some hassle factor and it's not dirt cheap when you include brakes. But it doesn't take up much space when you're not using it and it doesn't add tongue weight to your tow vehicle.
I haven't used a tow dolly, but they've got to be cheaper than a full trailer, and definitely smaller to store. But you still need to drop the rear driveshaft if you're going to follow the owners manual.
Trailers are nice, and I expect to move up to one at some point. But there are options.
Timstrk
Put #6000 behind whatever you're towing with and you are going to want brakes. One axle is good but two is better. Adds to the cost of the trailer but is an OMG upgrade.
Slednut10
Guru? That's funny!
Check your local laws (and where you will be towing)-some states require brakes on both (or all) axles.
Examples of what I deal with:
NH requires "adequate" brakes in good working order over 3000 lbs
VT require brakes on one axle over 3000 and both over 6000
ME requires brakes on every axle over 3000
MA doesn't specify brakes until your over 10000 (really?)
fatboy
Glad to be here.
New Hampshire
But Maine does not require you to title the trailer under 10K, NH however requires a title for anything over 3K I think... I found this out when I bought a 9995# GVW trailer out of Maine without a title and tried to register it in NH. Got it done eventually but it was a PITA.
sanndmann3
I borrow a friends trailer so it is definitely cost effective! ;)
I used to flat tow but no more. Hit a rough stretch of road and got the Bronco got all out of shape and almost crashed. White knuckle ride for sure...
Skiddy
same happened to me but with a tow dolly, no way would do that again
