Chowbird
- Jun 22, 2014
- 53
Hi guys. 352FE carbureted with points ignition. When cold, starts right up on first turn of key. No pumping throttle, just starts right up. Run it for a short time and it will not start if shut off. Cranks, shoots a miss or hesitation every couple cranks, no start. Will even die while running sometimes. Shuts itself off, coast to a stop, crank, no start
Checked battery. 12.6
Checked alt. 14.8. 13.8 with everything on
Held throttle wide open and cranked. No help
Shot starter fluid down throat. No help
Put a little gas down throat. No help
Checked for spark at distributor from coil. Yes
Checked for spark at the plug... NO. (May be operator error checking for this spark, but I'm reasonably sure there is none)
Does this mean bad distributor? Or rotor. How can I check the rotor, just take off the cap and have someone crank it?
Would heat cause these problems in the distributor?
Thanks a bunch
Tim
Thanks a bunch
Tim
