cross enterprises rear shock mount part 2
76 explorer
oklahoma city
well as you guys know i have my lift and shock mounts on now but my shocks seem crowded. what hole in the inboard mount do you guys use? oh yeah and what suspension and body lift if any do you have.
76 explorer
76 explorer
oklahoma city
measurements are 26 extended and 16.125 compressed.
3.5 inch bc lift with a 2 inch body lift.
am i smoking crack or am i really using the wrond sized shock? or do i just have it in the wrong adjustment hole
chuck
Ingram, Texas
I like to run the outside holes. if that picture was taken on with the wheels on the ground the shocks are too long.
76 explorer
76 explorer
oklahoma city
ok.... thats what i was thinking also... yes the wheels are on flat ground?:?
which leads me to this question.... i thought people were running 10 inch travel shocks with this set-up....
chuck
Ingram, Texas
All Broncos are not the same. That is why I always tell people to measure their travel.
When I install the hoop I put it up hi and a little foreward (6")at the top
huged29
Ft Collins, Colorado
You have to think how you want your suspension to flex when you pick what length shocks you want. Looking at your picture you have about 2-3 inches of up travel and the rest downtravel. This doesn't mean your shocks are too long, it just means that your tires will droop more then they will stuff. If the rest of your truck is set up accordingly (bump stops, brakes lines, etc) then there is nothing wrong with that setup. It all depends on how you want it to behave.
For example I have 3.5" suspension and 2" body and I set up my front axle for about 3" of up travel and 9" of downtravel. I haven't tested it too much but hopefully it works well.
Case
By moving the top of the shock in, you dont need to run as long of a shock because of the angle.
