Custom radius arm length
crawler73
Are all you guys/gals out there doing semi custom or full custom suspensionÂ…..what are you finding to be a good length for the radius arms?
rguest3
You will see completely stock replacement to Full Custom Suspension systems here.
Stock length Radius Arms for the most part.
James Duff, Toms and others have extended Radius Arms. They usually recommend at least a 3 1/2" Suspension Lift for these.
Apogee
Tangent, OR
My CAGE arms are ~45" from pivot to axle centerline, give or take, and work pretty well with a 3.5" lift. Compared to the factory radius arms, it flexes much better and has more body roll on the street, as expected.
savage
Bronco Nut
Renton
I think it all depends what your going to use the Bronco for. I wanted something that work well on and off road. I went with the James Duff T-REX arms, which are stock length, and bolt on with no modification, and they flex well and you get your turning radius back!! They flex well ,but don't give you the body roll on the road ,like the James duff long arm's do.
Yeller
Rogers County Oklahoma
I'm not sure of your build goals are, I'm not a radius arm fan. They work, and longer does make them better but if links are in your wheel house, they are superior and make the truck better balanced. They have to be done correctly, there are a ton of bad designs that have been done over the years (and still being done) but there is major improvement that can be accomplished with them. But for a reasonably simple bolt on the longer radius arms on the market do offer a substantial improvement.
C
crawler73
I have links up front with Johnny joints. Right now I'm 41” from center of joint to center of joint and 44” from back of axel to center of joint at the frame side. I bought new tubing because I have more of the shaft of the joint showing than I want (weak point). I figure I would check with everyone and see what lengths everyone is picking when they going with a custom set up.
