Slow_bronco
- Jun 12, 2016
- 1
Hi there, new member on the forum, so please bear with me
I have a question about a 2 different sets of cylinder heads for my bronco. I'm curious about the differences between the factory c8 heads from my bronco and a set of e7s that I have laying in my garage from an engine I bought for my mustang. Keep in mind the c8s are all original fomoco pieces from the factory and need to be pressure tested and rebuilt (cylinder 8 was full of antifreeze when I pulled the head, as well as corrosion/build up from burning of coolant on combustion chamber and valves on head) and the e7s have less than 1000 miles on them from a rebuild (bought the motor out of a wrecked 95 cobra that had a recent rebuild. If there is no huge differences other than the obvious differences in combustion chamber and rocker arms that I can see, then has anyone run these heads on a early 302 and were there any further modifications needed such as push rod length and so on.
Thanks in advance!
Thanks in advance!
