When reassybling T case for Tera low gears I ran into a issue installing front output shaft "front bearing". When using Front yoke to push bearing onto shaft the yoke bottomed out againts the shaft splines before bearing seated against C-clip (about 1/4" between bearing and C-clip. Has anyone ran into this before? Do I possibly have a J-shit yoke and need a spacer between yoke and bearing? I have seen pictures posted with 1/4" of shaft splines past face of bearing, is this space exeptable between yoke and bearing?
Thanks in advance!!
Thanks in advance!!
