- Aug 3, 2012
- 123
What would cause my D20 rear output shaft, outer bearing to get chewed up like this? This is the second time this particular bearing got chewed up. I recently converted to an NV3550 transmission and while I had everything out I decided to rebuild my transfer case. When I first disassembled the transfer case, the rear output shaft outer bearing was chewed up as well. I measured the endplay at .003 when I put it together. Yoke nut properly torqued. I'm afraid it's going to happen again if I don't figure out what's causing it.
