kiteoregon
- Nov 21, 2011
- 292
I have pulled the engine, transmission and transfer case, now i need to pull the transfer case from the transmission. I was reading that i need to unbolt the transfer case just behind the transmission, but before i do i need to put the trans in first or all of the needle bearings will fall all over the place. So the question is, since i have the transmission linkage disconnected do any of you know what configuration would put the trans in first? I have the stock 3 speed manual, believe it's referred to as a top loader.
Thanks.
Thanks.
