I am installing bigger gears in my Dana 44 but the pinion is not dropping out. I removed the ring and carrier then the pinion nut and yoke. The pinion slides out but the big flat washer is hitting part of the housing on its way out. Am I missing something here?
You get the outer bearing out of the way? When I recently did my D44 I noticed that when I went to remove the pinion I tapped it in, but then to get it to tilt a bit so it would come out I had to first remove the outer bearing. You can tap the pinion in enough so the bearing gets loose and you can slip that out. Then the pinion should tilt enough so you can work it out.
Are these the stock 3:55 gears? IF so, they have little to no value, get out a hammer and tap away.
The outer bearing sticks pretty bad, it just needs to be free'd up.
