D44 re-assembly question
Bukin 67
Bronco Abuser
I'm replacing the stock pass side axle with a chrome moly.
the old inner axle had what looks like a grease slinger at the opening to the housing (left pic)
The new axle (right pic) doesn't, or am I missing something? It appears that the new axle will rub against the housing once installed?
Zillacon
Hackin Away!
I just installed some in mine. The slinger is not required on the New ones and yes it looks close but didn't hit or rub on mine. Once you get the outer stuff and lockouts on it will pull it out a tad.
Bukin 67
Bukin 67
Bronco Abuser
Thanks Zillacon
appreciate the input...i was hell-bent on getting frustrated, thinking I forgot something so that helps a lot :cool:
