D44 spandle bolt pattern
u0061914
Prior Lake, MN
Does anyone know the diameter and bolt pattern of a dana44 spindle? (where it bolts to the knuckle). I need to order some shims to correct my camber issue and the parts store needs to know, the diameter, # of bolts and bolt pattern.
u0061914
u0061914
Prior Lake, MN
One other question. My current camber specs are 1.1 on the left and .8 on the right. My tires sit like \ / when you look at them. I was going to bring them back to exactly zero degrees. I assume that would be OK?
stlkikn
Specs pulled from my factory 69 manual... 1-2 degrees of camber with 1.5 being optimum.
