Can the FS Bronco steering be used and the track bar?
The FS tie-rod could be re-used on the FS housing of course, but the draglink might have to be shortened. Yes, the lower mount is now farther away from the pitman arm, but I don't think it's quite far enough. Perfect time to add an adjusting sleeve though, to make it more versatile.
The EB and FS trackbars are different lengths, but I'm not sure if the longer one will fit or not. Sounds again like time for an adjustable one. With all of the changes, the likelyhood of either of the stock ones centering the axle properly is pretty slim.
Might just depend on how much lift you have and if you're feeling lucky.
I have welded the carrier in the front. Can i still use that but swap to high pinion gear set?
If you mean can you use the welded diff along with the reverse cut gears in the FS housing, then I think you can. If I'm not mistaken the differential case is the same between the two assemblies. Just the gears have different profiles.
But like broncnaz said, your custom "spool" might just be why you broke an axle and you'd have to re-set the diff. Chances are you'll have to go through all the rigamarole of gear setup. Better to weld the new one. Or, just not do it and say you did.
One more thing. If you're swapping out the axle shafts into your EB housing, what knuckles do you have? Ford? GM? I thought I heard somewhere that the larger u-joint axles don't fit in to all the knuckles. Maybe it was just the early drum brake knuckles, but it might be worth asking those that know.
