BUY IT!!!!! Thats one of the most desired years. (78/79) Yes you can grind off the perch. If I remember right you have Cage arms? If you do, save yourself the time and headache of making the old wedges work and buy the weld on brackets from Cage.
Just my .02
I cant get the pic to enlarge, but is the cage bracket right beside the cast in perch? if so I should be able to do the same thing. I dont have cage arms...just longer bronco bob's(all4fun offroad)-thanks!Chuck
I would still like to see some other pics from people...keep the info coming please!
The Ford 78/79 HP Dana 60's are one of the most desirable and hard to find Dana 60's. Just make sure it really is what they say it is. On the 78/79 the diff will be closer to the center than on later years, and the spring perches will be closer together because the frame rails were narrower on the 78/79 Ford trucks.
The perch was cut down from mpcrewcab when I bought it from him. The bracket is close but still had room to get the welding gun in there. Try this link http://classicbroncos.com/forums/showthread.php?t=98003
If you scroll down the picture is there and it should enlarge.
