The new Dakota Digital coolant temperature sensor is so close to the distributor that I doubt I could connect the wire to the plug.
You guys have any good alternate spots? There is a port headed toward the heater core but I worry that it would not have any flow. Also a port on radiator side of thermostat which doesn't seem ideal as it wouldn't be engine accurate if thermostat was closed.
Thoughts??
Thoughts??
