Mark1911
- May 14, 2017
- 148
Good evening. Is anyone running the Dakota digital GPS unit for speedo?
I am using the RTX speedo/gauge set up from Dakota digital and a ford fuel injected 347. The Ford ECM requires 8000ppm and the supplied Dakota digital speed sensor is 16000ppm digital sender. So to simplify things I was thinking hey why not GPS? It has a output for 8000ppm sine wave signal the ford ECM will like and less wiring. Anyways is anyone using this type of set up? Pros? Cons?
Thank you for any input.
Mark.
Mark.
