Damn.....
73stallion
Eugene, OR
That is all, just Damn......
NGABronco
N. GA now South Carolina
Aw stallion, come on!!!! You've been living on the left coast too long!!! You're starting to believe all that "no rust" stuff!!!!;D;D;D;D That's a simple floor board patch, you won't even need to cut out the toe board (well maybe)!!%)%)
They come a whole lot worse on this side the world!!!:cool::cool:
malonejy
Hey Ben, you doing some kind of Flintstones mod or something?;D
73stallion
73stallion
Eugene, OR
actually i think most of the damage was done in texas, with all the rain we had while i was there. i have a new floor pan, but nowhere to install it......
maybe i should throw a pizza party and get some help down here???
sprdv1
REBEL
Well damn the luck... Yeah pizza and beer party should get folks over there.
mattyq17
Just put the carpet back over it!:p Too bad you werent closer I would help
bigmuddy
Marthasville Missouri
Don't know an experienced bronco mechanic do you?;)
Looks like that has been coming on for awhile, and the Texas rain didn't do you any favors!
Rustytruck
Its been that way for 20 years why worry about it now? POR 15 whats left and then fiberglass it until your ready to fix it right. At least it lets out the floor board heat in the summer time.
half cab
Guru Bronco
Here in N. Ms. they would wiremesh and BONDO/RHINO the hellow out of it!!
reynard101
Nothing a 20 lb. bucket of roofing tar and some galvanized sheet can't cover up. You'll be good to go in no time. ;)
jw0747
San Antonio, TX
cut out a piece of half inch plywood...good as new. so that you can keep the built-in ventilation system drill a whole bunch of holes in the plywood. should work okay except for all the exhaust fumes and heat.
polarman
Bovina Center, NY
Not so bad. I riveted a galvanized sheet onto my floorboard about 15 years ago.I had to capture the parking brake cable so I could still use the P barke. I just recently stopped using it because the cable is no longer tied into the floor. A $10 fix for 15 years ain't bad. It wouldn't take much to cob that up until you find someone to weld in the new floor pan.
frenchy
Looks better than a northern Indiana Bronco. Yea pizza and beer should get it fixed!!
frenchy
