I have a '74 with twin stick shifters and can't get the front axle low range to shift in. It shifts fine on rear axle hi and low and also fine into front high but simply will not shift to front low. Before I pull the case I thought I would bounce it off you all for suggestions. I've tried rocking it back in forth hubs locked and open. Even moving the shafts while on the lift. Just won't go in.
Thanks in advance
Thanks in advance
