kiteoregon
- Nov 21, 2011
- 292
I was able to pull the gears off the output shaft of the adapter that is bolted to the stock transmission (3-speed), when i attempt to place the gears on the AA adapter the snap ring is not even close. See the first photo with the red line, this is the gap for the snap ring. Once the gear is on there the snap ring slot is somewhere in the middle of the gear. Are there different gears that are needed, or is the shaft on the adapter not long enough? Maybe with this setup you don't need the snap ring, i doubt it however.
AA Output Shaft
With Gear
KO
AA Output Shaft
With Gear
KO
