rockingm82
Dana 20 rebuild is a trying test for this new shade tree mechanic.
I have several questions.
1. The idler shaft: I read a rebuild post on the Dana 20 where the author mentioned an o-ring on the idler shaft. I don't recall one coming off during the dismantling operation and I didn't receive one in the rebuild kit. Is their actually a required o-ring for the idler shaft?
2. The Dana 20 is missing a shift pill. It had the shift pill installed in the sleeve that doesn't run completely through the case, but the shift pill is missing from the other sleeve (this is the sleeve you can see through if the rails are removed). Would there be a reason for a PO to remove this pill. Where the heck can I find a new one to replace it?
3. I received a round gasket in the rebuild kit and I have no idea where this goes. See picture one.
4. I'm a noob so forgive on this one, but there is one washer with two flanges on the inside that I'm not sure where it came from, nor can I find it in any manuals. See picture two.
Thanks for the help guys. This is my first attempt at a major project and I'm completely on my own outside of this website.
