Dana 20 Input shaft?
chriskent85
So I pulled my dana 20 and notices that the end of the input shaft has been cut down. Is there any reason why this would have been done or if it will affect it any?
WILDHORSES
USA
Guessing:) 3 speed to C4 conversion? That would be the only reason I could think of. The manual input shaft is about .5" longer than the automatic so it's common to cut the manual down to save some $.
Jim
Justafordguy
X2, on a 3 speed to C4 conversion. Gotta cut 1/2 inch off to make the adapter mate up.
C
chriskent85
Viperwolf1
electron whisperer
The difference is 3/8". You don't want to cut more than necessary because the inside splines are shorter in those manual spuds.
