The best I can describe it is when I’m rotating the gears the washer rotates about about one quarter of the way then it stops, then when I rotate it the opposite way it rotates back and then stops again. There must be some kind of channel that’s making it stop from rotating a full 360. I don’t see any movement or gap between the thrust washers and the gears.
That "play" you are talking about is normal. There are some little stops on the washers that keep them from spinning. They sit in grooves on the case. That is what you are seeing.
