dana 20 rebuild HELP Please
elkarcher
OK I am rebuilding my Dana 20 TC. I have got all the way down to the shift rails. I can't get them to come out. I got one to move about an inch or so. It wont go any further. Is there a certain way it needs to come out? Please any help will be appreciated. Tim
david heater
Westminster,Co
Did you pull the locking balls and springs? on the top of the shift rails there are 2- bolt heads you need to pull those and remove the springs and balls on then I beleive it is the high-range side shift rail you need to pull it and remove the inter-lock pill.
E
elkarcher
I pulled the two detent balls and springs out. I will go and look to see if I maybe missed something though.
E
elkarcher
I got all three out but there is still something holding in both shift rails. They are hitting something. I dont know what though. There is nothing else there.
70_Steve
Old Guy
From the service manual. Rear shift rail comes out first.
12. Remove the setscrew securing the rear shift fork to the shift fork to the shift rail. Then, remove the rear drive shift rail and fork from the case (Fig. 7).
[Editor’s note: In order for the sliding gear to be removed from the shift fork, the fork must be able to rotate all the way over to the inspection port. In my case this was not an option, since the shift fork stopped short of the inspection port. I solved the problem as described in step 12A below]
12A. Note that the rear drive shift fork is secured to its shift rail by means of a sunken, Allen head set screw. This setscrew could be removed with a 3/16” Allen key, but this could prove tedious since there is limited clearance, and the Allen key only affords 6 positions of grab. This inconvenience can be worked around using a 1/4”-hex-drive Allen-type bit – the type of bit that might be found in a universal screwdriver type tool set. Inset the (3/16”size) bit into the setscrew. A 12-pointed 1/4" box end wrench may now be used to turn the Allen bit, removing the setscrew. The 12-point wrench affords more versatility than a 6-point wrench because of its in-between increments. Do not back the setscrew out entirely – just enough to free the shift fork from the shift rail. Once the shift fork is unsecured from the shift rail, the fork can swing freely on the rail and the sliding gear can be removed through the inspection port. Once the gear is removed, slide the shift rail out from the shift fork and out of the case. Remove the shift fork from the case.
13. Remove the front output shaft rear cover and shims. Tie the shims together.
14. Remove the front output shaft bearing retainer and gasket. Remove the retainer seal if it is worn or damaged.
15. Tap the threaded end of the front output shaft to remove the rear bearing cup from the case bore.
16. Wedge the front output shaft front bearing away from the main drive gear to allow removal of the snap ring from its groove in the shaft. Then, tap the shaft and rear bearing out of the case (Fig. 8).
[Editor’s note: Your J-shift case MAY NOT have the aforementioned c-clip on the front drive output shaft in between the bearing cone and the high speed drive gear. If not, note that the front bearing cone is mildly pressed onto the shaft at the splined area. You are able to CAREFULLY (with a light hammer and a soft drift) tap the shaft assembly toward the rear of the case, driving the front bearing cone off the shaft. You can now remove the shaft assembly.
17. Lift the sliding gear, main drive gear, front bearing, spacer, and snap ring from the case.
18. Remove the front cup from the case bore.
19. Remove the setscrew securing the front shift fork to the shift rail. Then, remove the shift rail and fork from the case.
20. Remove the detent rods (Fig. 9).
E
elkarcher
I got all of this. Thanks for the help. I got the two allen head screws out. The forks slide good but the detent rods will not move but an inch. I dont want to tap on them any more something is holding them up on the case but I cant see anything at all. The front shaft will not move out at all. the rear moves but only a inch or so. I will have to go look at it a little bit more and figure somthing out. Thanks guys for the help. Tim
E
elkarcher
Hey all thanks for the help. I took out one of the seal on the detent shaft and they fell out. Dont know what the heck but they are out. Thanks Again. Tim
