Dana 20 rebuild progress pic
skrit
A Horse with No Name
Durham
Thought I'd share a peek at my Dana 20 rebuild. I'll post more on my build thread. Wish the case tag wasn't so faded.
skrit
skrit
Durham
Looks great. Is it bare CI or painted? If coated with what?
Scrubbed it with mineral spirits and a brass brush, coated with Rust Reformer, then engine primer and finally Cast Blast rattle can paint in cast iron color. Decided to do new goldish colored anodized grade 8 bolts I got from O'Reily's.
Soylent
California
Were you having any issues before the rebuild? What rebuild kit did you use? The full monty from WH?
skrit
skrit
Durham
I was not having issues back 10 years ago when my Bronco was actually assembled other than leaks which seems to be very common I'm doing a complete frame off so I figured, might as well rebuild it.
It's a fairly easy rebuild. No gears were worn or damaged so basically it was a tear-down, clean, re-bearing, re-gasket/seal and paint operation.
I bought these tools for the job from HF:
https://www.harborfreight.com/bearing-race-and-seal-driver-set-10-piece-63261.html
https://www.harborfreight.com/bearing-separator-and-puller-set-62593.html
I heated most of the bearings in an oven at 325 degrees for 15 minutes and they pretty much fell into place. Others, I used a MAP torch to heat up. I used the cheap transmission clutch press I bought from Amazon for the 4R70W rebuild to press the bearings on the rest of the way. For one of the bearings, I used a 1-1/4" cast iron pipe coupling and nipple to help press it on.
I got the rebuild kit from here: https://transpartswarehouse.com/bk2...nsfer-case-rebuild-kit-1966-1972-dana-20.html
After finding some scoring and excessive wear on the intermediate shaft, I ordered a "hardened" one from here: https://thejeepsterman.com/products...nsfer-case-1947-1986-willys-and-jeep-vehicles. It has not arrived yet so I hope it works for the Ford Dana 20.
I also ordered adjustable shift rail detents from JB fab.
chrlsful
I usta like the "Low D 20” K Bar S usta sell. Justa lower 1s gear to stuff in the housing, simple/cheep. Forged by TerraFlex’n called
the terraflow I think WH was the last to sell them. May B .5 a lower x-fer case (3 even steda 2.46 I think). The heep model will not fit in our case or sumpin. (Woulda liked 4:!! x 3 x 15 better than 4:11x2.46x15 inch, a 50 v 80 final drive, perfect 4 me/my conditions ~ 5 MPH in 1st& low - I seek an 60 to 80:1 ratio).
Soylent
California
Thanks for the detailed response!
