Krusher
I have been having speedometer fluctuation problems since my rebuild. I believe I have it narrowed down to the speedometer gear and shims on the Dana 20 rear output shaft. As I understand it, if the shims are not applying sufficient pre-load pressure on the bearing, the speedometer gear will slip.<br><br>Now the question. Can I remove and replace the speedometer gear and shims without removing the entire rear housing assembly??? <br><br>Thanks in advance for the help.
