Dana 20 transfer case shift know options
jkruse76
Hello all,
I have a 74' with a Dana 20 in it . The hurst shifter on the trans and the t shift on the transfer case keep getting in the way of each other when I shift . I want to replace the t shift on transfer case with a different shift knob( because I like the hurst shifter knob) but it needs to have the push button located on the top. I have looked at the one from toms , it is the billet shifter with push button on top. Just wondering if there are any other options out there . I have searched all over the internet for other options , but with no luck. Anyone recommend a site with top end push button transfer case knobs or come up with any other solutions....what have you all done that run into this issue....any advice would be very appreciated...thanks in advance.....
broncodriver99
Glen Allen, VA
A '74 should be a J shift transfer case. Someone must have swapped in a T case. Wild Horses has some shifters as well. If you aren't set on having the push button you can just remove the detent plate and run a standard aftermarket Tshifter with no locking button.
WILDHORSES
USA
