Hello,
I noticed some oil under my bronco this weekened. It looks like the oil is coming from the pinion seal on my frint axle, a dana30. How do I replace the seal?
1. Do I need to remove the cover plate, differential, ring and pinion and then replace the seal from the front side?
2. Do I drop the drive shaft, remove the yoke and replace the seal from the backside?
Looking at the exploded view I am thinking I need to go with #2. Also I am wondering about the preload when I put it back together. How do I measure and adjust the preload? Do I use shims or a crush sleeve? If a crush sleeve how does that work? If shims do I ust buy new ones and measure to the same size as what is currently in there?
Replacement parts should include?
1. pinion seal
2. new shims or crush sleeve?
3. anything else?
Thanks for any help,
Mike.
1. pinion seal
3. anything else?
Mike.
