Are you doing this as a one time thing, or do you do alot of differential repairs? If it is only periodic, I have had good success without one. <br>With the carrier bearing caps quite loose, but still in place to prevent the carrier from falling out, I hit the axle housing next to the bearing cap areas (both sides) with a 3lb dead blow mallot. The carrier will usually either move then or with mild, even pressure with a pair of pry bars on both sides of the carrier. <br>The moderate impact of the hammer seems to relieve the tension on the carrier bearings, allowing it to come out. When installing, with all bearing races and shims in position, a little pushing or Light! tapping with a hammer has always worked for me. <br>If you don't have a dead blow, another decent size hammer with a board or something to protect the impact surface should work. <br><br>Good luck!
