dana 44 front diff rebuild
boydknudsen
Watertown
I started out to replace the pinion seal on my front dana 44 of the 74 and it looks like the failure was caused by too much shimming on the pinion that doesn't allow the rear bearing to seat. This caused the pinion to move forward and back and sagging on the rear seal. At the same time it seems that my backlash to the ring gear is too much. The gears and the inside of the diff look great with no visible wear to my untrained eye. I have the manual from ford to rebuild but don't have the tools to follow that process.
Can anyone recommend a place to start and good practice that will get the job done fairly well?
RonJones
I haven’t messed with the pinion, but I didn’t need a stretcher to pull the carrier out and put it back in, merely pried on the ring gear to get it out/rubber mallet to get it back in and used a long set of socket extensions and a large socket (?1-1/8”) to replace the axle seals. Be sure to mark the bearing clamps to maintain orientation. HTH!
OX1
Dana's are tough to set up. The pinion shims require removal of bearing race
in diff casing, each time you want to try a new shim setting up
pinion depth.
Differential bearings are the same deal, and need both diff bearings to
come off every time you want to check backlash.
You can make "setup" bearings and setup bearing race by grinding out lightly
edges of races so those 2 bearings/race, slip on/off easy until you find the shims
you need/like. Then use new bearings/race for final assembly.
Are you familiar with ring and gear patterns, what they mean and
what shims to change to correct them? If not, you need to be.
After that, you need pre-load shims, which requires in-lb torque wrench
if you don't have a real good feel for what pre-load should be by hand.
You also most likely have a gear set that while it looks fine, has worn
in incorrectly. If you re-use, they might whine once set up correctly.
May not be a big deal to you if you use 4WD sporadically and/or under mild
wheeling.
EDITED: At first I was describing pinion shim location on ford diff's.
Danas go under bearing race in housing.
B
boydknudsen
Watertown
I think I'll shop around locally to see who might be able to do a rebuild. If it's only a few hundred to have someone do it, worth it. Spend my efforts elsewhere.
thanks guys
