Should the upper ball joint insert pass through the yoke?? Is this OK??
I am replacing the ball joints on my pass die after snapping the ears off inner and outer axle shafts and finding my upper ball joint very loose at least a 1/4 inch play.
Upon removal I noticed the insert was threaded into the hole to the point that there were several threads exposed inside the yoke. First pic on the left is removal.
The next two pics show the new ball joint and new insert on install. It threaded through the hole and was compressing the ball joint rubber boot/seal and still didnt reach the 40ftlbs of torque. This is with the lower ball joint nut torqued to 80ftlbs.
