So I have been a long time lurker and gotten a lot of info over the years.
I have had my current 77 Bronco since 2010 and have over the years done upgrades as needed. This year I got to do one I wanted. I added a 5.5" duff lift and 37" tires.
During my costing out of re-gearing I got a quote from a local Ring & Pinon Shop for $2300 to install an e-locker and 5.13 gears. I also found a company in Nebraska that would build me a Dana 44HP housing with the e-locker, gears and all the brackets for $2900 shipped to my door.
I opted for the HP and made my order back in May. Since then It has been shipped back and forth 3 times. I just received it back and the axle housing seems short to me. Here are my reasons.
1. The top ball joint bolt to top ball joint spread on my old axle is 46 3/8" my new one is only 45 5/8.
2. The passenger axle shaft floats side to side about 1/4" the driver side does not float at all. I am used to the shafts being able to float.
I think the drivers side is too short and causing the axle shaft to have a side load against the spindle and the locker.
Is this an ok situation? I would think not but looking for input.
Anyone know of a shop in Michigan that can help me get this fixed if needed?
Any and all ideas will be appreciated. Thanks in advance for your time.
