ntsqd
heratic car camper
Thoughts on best brand for Dana 60 ring & pinions? OEM Dana would be my preference, but I have yet to find anyone listing the 4.30 ratio. Assuming that Dana 4.30's are NLA who is the next best brand to use?
Yup, I knew it wasn't EB.This is NOT in an EB. See my "Wagon" sig file link.
4.30 because that it what the math says my chosen tire size needs to run at the OEM RPM vs. Speed relationship already programmed into the PCM. I'm trying to leverage all of the work done by the PCM's programmers to extract the maximum range (mpg) from this vehicle. Front (well both ATM) are 4.27's, but that ratio was never made for a D60. 4.11's are too tall by a lot and 4.56's are marginally too short. My absolute worst case scenario fall-back position some time down the road when this axle comes online will be to re-gear the recently re-geared front to 4.56.
Absolutely, positively do not want a 14bff. Far, far too heavy for this use. Even a D60 is going to be overkill about 70% of the time, but building a FF D44 is just silly. At the very minimum it will get 14bff spindles and SAI 5x5.5 wheel hubs. I wouldn't be changing the spindles except that I've not ever found FF 5x5.5 wheel hubs to work with D60 spindles. I'll never, ever build a semi-floating axle. Might rebuild one or re-gear one, but never intentionally build one from scratch. It will be getting Explorer RDB's if I can figure out how to do it without costing a fortune or a huge bunch of mass. It will be getting a Tru-Trac, undecided on if 30 or 35 spline. 35 seems like the easy button since literally everything will be new, but I did that for the FSB's D60 and it ended up being a royal PITA, so I'm a bit gun-shy about doing it again.
I thought you were a technical guy.I have time to really look into the Unit Bearing option and weigh it's pluses & minuses. At my current understanding of them I think that that design would be more than suitable to this application.
