dana 70 to big?
Fatboy6200
ok i got a dana 70 out of an excursion free at wrk tday i know i will have to cut it down on the long side? i have a 79 hp 44 8lug i was going to use but i would like thoughts on the 70 any help would be great ;D;D
SpareParts
It will have a metric bolt pattern if it came from an Excursion. It would work fine if you found a Superduty or Excursion front to go along with it. You would have to use the metric wheels, but I you have to buy them anyways, whats the difference.
I am using a 14 bolt from a 79' Chebby, it came with 4:10 gears and cost a whole $150. So to use a more standard rearend with a standard bolt pattern you are not talking about a bunch of money. Get it, sell it, buy what you need!
David
Fatboy6200
Fatboy6200
cool i took it but its a front i have a rear 60 for a 79 f250 i know the lug pattern is different but is it poss. to change the rear to match the front i am doing a full rebuild lockers and 4link in the rear i just dont know if i shoud build the dana 44hp or the 70 for the front
cali_zuk
The excursion never had a dana 70. It came with a sterling 10.25 (same as 10.50) As stated above its a 8x170mm bolt pattern. That axle also came in a 8x6.5" on the pre99 superduty's, so you may be able to swap parts to make it work!
broncnaz
I think the excursion front axle is either a D50 or D60 I believe 2002 up had the 60 earlier had the 50's
Fatboy6200
Fatboy6200
thanks guys i will post pic tmarow i was told it was a 70 but i have no idea maybe with pics i can get a better idea
broncnaz
Well the D50 is stronger than a 44 and not quite as good as a 60 due to axle shaft size which is about the same as the D44 and uses the same ujoints as the big D44 axles shafts.
carter2772
Camano Island, Wa
Since its a front and it free, I would research it some more before you toss it. Depending on what size tire you want to run and what the use of your eb will mainly be for.
shonivey
also check on gear options before you put alot of money in it. quite a few axles don't seem to get the aftermarket support. some may be limited to 4.10 - 3.20ish. good for a daily but not what i assume you want for an offroader...4.56,5.13...
broncnaz
I think gears are availible for the 50 down to 5.38. I dont think theres a carrier split either.
Fatboy6200
Fatboy6200
I was planning 37 for street and daily and 39or40 s for trail. I just don't want to do thing twice if I spend the money on a 60 I'm done right?
broncnaz
Yeah you'd probably be better off with a 60. Axle shaft size and ujoint size is the issue with the 50.(basically D44 sized uloints but maybe slightly larger axleshafts. Otherwise from what I understand its almost as good as the 60.
I believe the D50 has a 1.31 dia axle shafts where the D60 has 1.5 dia shafts. And of course the 60 has a tom of aftermarket support.
SpareParts
The weakness of the D50 is the pinion, it had the same diameter as a D44. The spider gears in a D50 are a lot bigger that the D44. So they hold up better that a D44 does in general, but if you are thinking of running 40's then don't waist your time. It would be worth some coin to a StuperDuty owner though. I have seen a couple of them twist a pinion off.
David
