Hey all, finishing up a complete re-wire with the American Autowire Harness 510317 for a 66 restomod and have a couple questions.
1. Installed a single-DIN touchscreen radio head unit. There is an input for illumination. I also have extra wiring for the dash label lamps as mine is a 66 and did not have the illuminated dash labels. Are the dash labels always on or turned on with the head lights? I was thinking I could wire the head unit illumination to the 12v feed of the dash labels provided the dash labels run off head lights. If they are always on, any suggestions on where to tie into head light circuit?
2. Head unit has a reverse switch input for the backup camera. I assume this is wired into the feed out to the back up lamps from the back up switch (load side of switch, not 12v ignition feed to back up lamp switch.)
Thanks!
Thanks!
