Dash Pad Removal INFO quick, Please!
bills_69eb
I am having my 1969 EB repainted. It is in the shop right now. I will be replacing all the rubber and the windshield. My dashpad is cracked but I have a 1974 Ranger EB that has the Best condition dashpad I have seen on an EB . I am thinking about swapping the two out. I recently removed the top on the 1974 and since the 1969 is in the shop I thought now was the best time to do it IF doing it isn't more trouble than its worth. Any help on how I should go about removing it? Is there some pitfalls I should look out for? Any help would be greatly appreciated.
Jeepster
Re: Dash Pad Removal INFO quick, Please!
just remove all the screws.....
Gummi Bear
Doesn't the windshield does have to be down to access all the screws? (I am taking mine off, always liked the no-dash look, also replacing the seals above and below the windshield frame)
Yellow75
Sioux Falls, SD
Take the 2 bolts out on drivers and pass. sides of the dash that you can see. Then you can fold your windshield forward a bit to get the screws across the back of the dash.
westco
Klamath Falls, OR
The dash pads you have mount the same. Remove bolts, one each side. This is where the knobs would be if you have a 67. Then lay down windshield and remove screws from both front and rear (in Cab) of rig.
