Dash switch ideas
AZ73
LOVE the dual full sweep fuel gauges....so cool.....and so then naturally assuming you are running dual tanks, is the tank transfer switch the one next to the lower fuel gauge? And my zoom made the details blurry, so is your ignition the one below the vent next to the tach or where did you mourt that?
Definitely not the norm, but I love it.
Thank you. Yes, dual tanks, dual gauges. The transfer switch is to the lower left. It switches the valve to draw from the aux tank and shuts off the rear tank boost pump. The high pressure pump is after the valve and the aux tank is gravity fed to it.
It has a push button ignition with the button next to the tach. It does really deviate from the norm, and frankly one of the key looks of a Bronco which was a tough choice, but as soon as I decided I needed something bigger to make it easier to read I fell into the "if some is good, more is better" trap.
