chuzie
- Jul 21, 2006
- 2,701
Looking to gather data from those running manual disc/disc brakes on D44 + 9inch axles with 35"+ tires please.
Don't want anything HB, vacuum or drum related. There's some good historical threads out there, but none that I found have stated data driven results.
Please provide anything you can below:
MC type
MC bore
MC stroke
Using prop valve?
Caliper application front (tbird, bronco etc)
Caliper piston quantity front
Caliper piston diameter front
Caliper application rear
Caliper piston quantity rear
Caliper piston diameter rear
Rotor diameter front
Rotor diameter rear
Pad type front (organic, composite etc)
Pad type rear
Pedal effort
Any axle mods?
Can you lock em up?
Effectiveness /Satisfaction with setup?
On/off road use?
MC type
MC bore
MC stroke
Using prop valve?
Rotor diameter rear
Pad type rear
Pedal effort
Any axle mods?
Can you lock em up?
On/off road use?
