date coded ignition wires
tbruz
Anyone know where to get appropriate date coded ignition wires for a 76 302???
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
GOOD LUCK ! I have a set of original wires off of a 73 that I bought. I saved them in case anyone was doing a restoration. They are probably the exact same wires. This is not GM we are talking about here. Very little was dated. You should find out what brand of wires were on there and go from there. :)
broncolove
The Bronco Ranch
S.E. Michigan
I have probably thrown away 3 sets of original 76 wires. They were all used pretty well though. Are they Really date coded?
jwh
My 76 302 has 1976 on the plug wires also. Still work fine. Well, the engine still runs:)
jwh
T
tbruz
Thanks for the replies...
I have the original wires(still work but not as good as a fresh set) and they are marked "Motorcraft Sipcon 1D6 1976" and are numbered 1- 8 for the appropriate cylinder.
The marking is white and the pattern repeats about every 8 inches...
I would think that any ignition wire manufacturer that makes wire sets for Mustangs would be able to make this set. I just don't know who make them for Mustangs??
TonyB
