mhinchliffe
- Dec 21, 2018
- 107
Not knowing the reason for the creases in my front fenders, I was wondering if any of you guys could shed some light on the most likely possibilities...
I have creased front fenders just like that. My rig spent its whole life as a hunting rig in southern Montana. I suspect someone did a couple sweet jumps in it at some point. My question is does anyone have any advice on pulling out the creases? I was thinking about removing the grill and putting something (2x4 lumber)behind the grill flange on the fender then hooking a strap to the 2x4 then hooking up to a tree and throwing it in reverse. If anyone has better suggestions I’d be really happy to hear them, until I build up the courage to hook my rig to a tree!
Once upon a time people took Broncos off road
We still do...
I'm far from a "certified body man".
I'm currently rebuilding a 1970 "rolled over" Bronco. I find it's much better to do the majority of the rough reshaping with everything still connected. Leave the grill attached to the fender and use a porta power to push the fender back out pushing back against the trucks frame and suspension. The weaker fender will move before you bend the frame. It's really all about the angle of the push, not how hard you push. You can do a lot of massaging with a five pound sledge and a length of 2 by 4. You have to do the "rough out" shaping before you begin the fine hammer and dolly work. Just keep in mind that you want to minimize any metal stretching.
John
John and KBpony
Thank you for the advice on dealing with the creases. I was actually looking at a come along tonight in the garage. KB when you used the come along did you leave everything bolted together? Thanks again for the help.
John and KBpony
