scottmcwms
I bought a used 9" Detroit Locker. I installed 4.56 gears and set them up with the proper backlash (6-9 thousandths). I installed the axles and when I turned the pinion both axles turned the same direction. So everything looks good.
I installed the wheels and tires and put the Bronco back on the ground. Now I can turn the pinion 5-10 degrees before it stops in either direction. I know something isn't right. I shouldn't be able to turn the pinion very much.
Any ideas on what is happening, or is this normal? I have never had a Detroit before.
Scott
Scott
