Different size NUTS
skifast
Sandhills, NC
Anybody else have different size nuts........on the rear shock mounts?
3/4 on one side 11/16 on the other, NC on the 3/4 and NF on the 11/16.
I guess someone stripped it in the past and threaded it with what they had:p
moe d
chicago, il
not suprised.. on these old rigs, i've seen regular and metric nuts and bolts, duct tape, gum, twist ties.. you name it and it has been done!
jboomer
Havelock, NC
Oh no, is that wrong!? :eek:
I'm not doing a 1st class job on mine, but I'm trying to eliminate everyone of these that I find! Of course, for the sake of time, instead of eliminating the hot wire to an old electric fuel pump that no longer works, you can do what my PO did and just wrap it around the axle a couple of times. The fire that results when it unravels and drapes itself across the muffler is a sight to behold, and the smoke....I'm fortunate I survived the pull over from the highway! If you can imagine what cheech and chong's early Bronco looked like, with my head hanging out the window!
skifast
skifast
Sandhills, NC
Don't get me wrong, I was just wondering due to everything else that I have done again. Wouldn't surprise me one way or the other.%)
I am also re-routing my fuel lines as the PO thought that running them across the frame and most of the time on top of the exhaust would be a GOOD idea?;)
BroncoDawg
Bishop, CA
My wife has different sized boobs, but never heard of your issue! Sucks to be you.:D :eek: :-[ :cry: ;) Ooops, only read the header!!
