Dip stick tube part # ?
bax
Old Member
I have an E7 block with a push in pan mounted dipstick. The dipstick tube is missing so that means I need to find something that fits. The push in pan mounted tubes are my least favorite design. it's almost worth buying a new pan to get the screw in dip stick. I was wondering if anyone has had good luck with the push in tube not leaking and if so do you have a part number? Any help here would be much appreciated.
Is the dipstick hole on the passenger side? Even with your ‘80s block, that sounds like it might be a standard bronco pan.
Or did they carry the push-in design to different later models as well? I wonder if one of the dipstick tubes meant to push into the hole in the bottom of a later block, is also the right size to push into the pan?
